rheostat or potential meter?
Discussion in 'General Electronics Chat' started by cczone, Dec 26, 2008.
  1. cczone
    Dec 17, 2008
    23
    Might be doubtful wondering is this a potential meter or a rheostat?
    Or basically both have similar functions? Thanks for advice.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The schematic you posted is a potentiometer wired as a rheostat.
    It provides a means of changing the resistance between the symbol labeled UV (whatever that is) and the wire that goes off to the right.
    A potentiometer has 3 terminals and can be wired as a potentiometer or as a rheostat. A true rheostat has only two terminals, and can only be wired as a rheostat (provides series resistance).
    If a potentiometer has one end terminal connected to a voltage reference level, and the other end terminal connected to a different voltage reference level, then the middle terminal (wiper) can output a voltage potential anywhere between the two voltage reference levels.
  3. cczone
    Dec 17, 2008
    23
    Thanks for your reply. As i know potential meter has a knob and 3 pins ...
    wired as rheostat means...?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It is called a "potentiometer" (also called "pot") not a "potential meter".
    I added more information to my original post.
  5. cczone
    Dec 17, 2008
    23
    ok..thanks.....got it..
