RGB Wiring Schematic
Discussion in 'The Projects Forum' started by AK1, Oct 22, 2015.
  1. AK1
    Oct 22, 2015
    8
    http://www.amazon.com/gp/product/B010SKQU3C?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
    http://www.amazon.com/gp/product/B008GY6WM2?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
    Hi all - I'm making a box for some radio equipment and I'm a sucker for aesthetics. I want to light the interior of the box with these RGB LED's and use the controller for the color. I've attached the two items I've purchased.
    The power source will be 12V. I'm not sure if I wire these in parallel or series, and do I need a separate resistor for each color? I want to wire all 10 together.
    Thanks!
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Greetings! And welcome to AAC!
    The Projects Collection (as opposed to The Projects Forum) is for sharing completed projects.
    I've moved your post into The Projects Forum, where it will draw more responses.
    Good luck with your project!
  3. TheButtonThief
    Feb 26, 2011
    219
    38
    Hi.
    The LED's appear to have a Vf of 12V and the supply, also 12V. However, unless the supply somehow limits the current, it's not as simple as just connecting the LED's to the supply. LED's are current driven, not voltage driven so where as the LED is 12V and the supply is 12, doesn't mean that the LED's won't burn out as they'll be venerable to little fluctuations in the supply.
    Best thing to do would be to use the same supply but with lower voltage LED's and then limit the current with resistors. Also, yes you would use one resistor per colour.
    Hope this helps
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    They already have a single current limiting resistor on the common lead under the shrink tube. Just need a 12V power supply and you should be good to go..
  5. TheButtonThief
    Feb 26, 2011
    219
    38
    Well spotted, I didn't see that.
