Cannot defeat MCLR resistor But the resistor moving is not bad.
When I say minimum space I mean minimum u dummy's. Really.
But I got riddle for u.
Will u put resistors in around 0.25mm Coil diam enameled wires, which by the way I will use to wire up the circuit.
Sorry Guys, vertical height cannot go beyond DIL height. Wires are routed surprisingly in tight areas. It's a bit technical
Cannot show u cause if I did, Mod's will have an itchy trigger finger on this.
Tell u later.
and NO sockets.
{ed}
What about SMD high power resistors. Are they available.
But we might need to scrunch some numbers to find the power dissipated.
As u know I am not online too often in the last few days. That's why I am allowing jens to do this. other wise I would have given the layout. Been bzy to rap up things before I ship out.
Tell u later.
and NO sockets.
{ed}
