I'm making some RGB LED lights, using these buck puck drivers,
http://www.luxdrive.com/content/3021-BuckPuck.pdf
My question is, for the output leads that go to the LED strings, can I tie the ground sides together (and run less wire)? They are diodes after all but I don't want to screw up the current sensing in the drivers by adding something else to their ground output pins. I've always kept them separate in the past.
Here's a rough schematic
http://screencast.com/t/x1mZJZ1u
Thanks!
Thanks!
