RGB Circuit
Discussion in 'The Projects Forum' started by RodneyB, Feb 23, 2013.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    652
    14
    I am buildig an LED RGB driver. I have common Anode RGB's and the circuit diagram uses common cathode RGB's they are turned on by a 2N3904 NPN transistor. How do I use the same circuit to turn on the transistors but drive RGB's with a common Anode.
  2. ScottWang
    Aug 23, 2012
    4,933
    777
    You can choose 2N3906 that is the complementary type of 2N3904.
    E - Vcc, B - input, in series a Rb, C - Anode of LED, in series a Rc to limit the current of LED, the circuit similar as NPN transistor.
    Just don't forget to adding the Rbe resistor.
    RodneyB likes this.
