Rg for igbt module
Discussion in 'The Projects Forum' started by jm-a, Jul 9, 2012.
  1. jm-a
    Thread Starter Active Member
    Oct 20, 2010
    105
    Hi all,
    Just one question about igbt module:
    Reading FS50R12W2T4 , no need to add Rg resistor - p 2/8 internal gate resistor 4 Ohm
    Right or wrong?
    Thanks a lot.
    jm
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    the gate resistor is to prevent oscillations know as "ringing". Gate resistor is needed. Read about ringing gate.
    jm-a likes this.
  3. Skeebopstop
    Jan 9, 2009
    358
    It can be true that depending how fast you want to push a device you may want to avo id external gate resistance but at least design in the option. The switching speeds of IGBTS isnot very fast so I doubt Speed is a concern and integrity is more important. Usually clamping Zener at gate 18V and a lower impedance turn off resistor forMiller clamping. If powers are small 10R will generally do the trick and don't need to be fussed about the rest.
