RFID
Discussion in 'The Projects Forum' started by Cerkit, Nov 17, 2009.
  1. Cerkit
    Thread Starter Active Member
    Jan 4, 2009
    275
    Hi. I would like to setup a system similar to a car key distance detection whereby I can detect if a key is within a certain perimeter from the 'interrogater' station. I need to do this for a system with 4 keys. What system can I use? How do I set it up?
  2. Duane P Wetick
    Apr 23, 2009
    408
    19
    To detect something at a distance using RFID, the antenna has to be fairly large; (4" lgt.) I have a sample in hand. There are other limitations too; metal objects can shunt the antenna, so that you cannot interrogate it. Also, 32 bits seems to be the limit on memory, although that is likely to change to 64K (Boeing) soon, if not already.
    Some thoughts...DPW
  3. BMorse
    Sep 26, 2009
    2,675
    234
    Check out sparkfun electronics, they have a USB and Serial RFID interrogator module and different types of RFID tags available.....
  4. Steve C
    Nov 29, 2008
    86
    Search ebay for K9 sombra. Cheap as heck. You'll need two units to get four RFIDs. Security will be enhanced as well as having an RFID bypass option. I like it because the rfid appears to be an enabler, not the accesser. Uses a more traditional coded RF transmission to do the actual detection. So if someone spoofs your RFID they still wont have the coded RF signal needed to enable a detection.
  5. Dan-O
    Jul 26, 2009
    38
    I'm currently using a K9 unit as the passive security for a pushbutton start system on my car. It works great and hasn't missed a beat.
  6. Steve C
    Nov 29, 2008
    86
    How are you guys terminating the starter pulse? are you guys coming up with your own tachometer sensing capabiity are are you guys just adding a timer?
  7. Dan-O
    Jul 26, 2009
    38
    Check out my thread.
    With my version you have to hold the button to crank.
    When you release the button, it stops cranking.
    I use a 556 as a flip flop to turn the car on and off.
    I'm re-designing it and using a different IC
