I am trying to connect an iMAX Black Label scanner to a computer with its serial port. I haven't found any info on how to use the scanner's port. Any help would be appreciated.
You should just be able to connect it to a serial port on the PC and open a comm port application like Hyperterminal, if you have the BAUD rate set correctly in the terminal program, you should see it display data from the scanner right on the screen.....
