RfID reader C code
Discussion in 'Embedded Systems and Microcontrollers' started by LauraB, Dec 15, 2011.
  1. LauraB
    Dec 15, 2011
    43
    Hey Everyone
    I've built the circuit using PIC16F887 (on PicKit 3) and Micro RWD MF-IC.
    http://www.ibtechnology.co.uk/pdf/MF_ICprot.pdf
    I have this
    Code ( (Unknown Language)):
    1. Kod C - [rozwiń]
    2. #include    <pic.h>
    3. #include    "sci.h"
    4. void main(void)
    5. {
    6. // 8-bit mode at 9600 baud using polling
    7. unsigned char data,a=0;
    8. sci_Init(9600,SCI_EIGHT);
    9. sci_PutByte(0x55);  /* send 0xaa when device is ready */
    10. data = sci_GetByte();   /* read data when device is ready */
    11. a=data;
    12. }
    1. #include <pic.h>
    2. #include "sci.h"
    3.
    4. /* Routines for initialisation and use of the SCI
    5.  * for the PIC processor.
    6.  */
    7.
    8. /* other options:
    9.  * frame errors
    10.  */
    11.
    12. unsigned char
    13. sci_Init(unsigned long int baud, unsigned char ninebits)
    14. {
    15.     int X;
    16.     unsigned long tmp;
    17.
    18.     /* calculate and set baud rate register */
    19.     /* for asynchronous mode */
    20.     tmp = 16UL * baud;
    21.     X = (int)(FOSC/tmp) - 1;
    22.     if((X>255) || (X<0))
    23.     {
    24.         tmp = 64UL * baud;
    25.         X = (int)(FOSC/tmp) - 1;
    26.         if((X>255) || (X<0))
    27.         {
    28.             return 1;   /* panic - baud rate unobtainable */
    29.         }
    30.         else
    31.             BRGH = 0;   /* low baud rate */
    32.     }
    33.     else
    34.         BRGH = 1;   /* high baud rate */
    35.     SPBRG = X;  /* set the baud rate */
    36.
    37.     SYNC = 0;   /* asynchronous */
    38.     SPEN = 1;   /* enable serial port pins */
    39.     CREN = 1;   /* enable reception */
    40.     SREN = 0;   /* no effect */
    41.     TXIE = 0;   /* disable tx interrupts */
    42.     RCIE = 0;   /* disable rx interrupts */
    43.     TX9  = ninebits?1:0;    /* 8- or 9-bit transmission */
    44.     RX9  = ninebits?1:0;    /* 8- or 9-bit reception */
    45.     TXEN = 1;   /* enable the transmitter */
    46.
    47.     return 0;
    48. }
    49.
    50. void
    51. sci_PutByte(unsigned char byte)
    52. {
    53.     while(!TXIF)    /* set when register is empty */
    54.         continue;
    55.     TXREG = byte;
    56.
    57.     return;
    58. }
    59.
    60. unsigned char
    61. sci_GetByte(void)
    62. {
    63.     while(!RCIF)    /* set when register is not empty */
    64.         continue;
    65.
    66.     return RCREG;   /* RXD9 and FERR are gone now */
    67. }
    68.
    69. unsigned char
    70. sci_CheckOERR(void)
    71. {
    72.     if(OERR)    /* re-enable after overrun error */
    73.     {
    74.         CREN = 0;
    75.         CREN = 1;
    76.         return 1;
    77.     }
    78.
    79.     return 0;
    80. }
    81.
    82. #define sci_PutNinth(bitnine)   (TX9D = bitnine?1:0
    83.
    84. unsigned char
    85. sci_GetNinth(void)
    86. {
    87.     while(!RCIF)
    88.         continue;
    89.
    90.     return RX9D;    /* RCIF is not cleared until RCREG is read */
    91. }
    92.
    93. unsigned char
    94. sci_GetFERR(void)
    95. {
    96.     while(!RCIF)
    97.         continue;
    98.
    99.     return FERR;    /* RCIF is not cleared until RCREG is read */
    100. }
    101.
    102.
    103.
    1. #define FOSC    (4000000L)
    2. #define SCI_EIGHT   (0)
    3. #define SCI_NINE    (1)
    4.
    5. unsigned char   sci_Init(unsigned long int, unsigned char);
    6. void        sci_PutByte(unsigned char);
    7. unsigned char   sci_GetByte(void);
    8. void        sci_PutNinth(unsigned char);
    9. unsigned char   sci_GetNinth(void);
    10. unsigned char   sci_GetFERR(void);
    11. unsigned char   sci_CheckOERR(void);
    12.
    13.
    14.
    But I can't program it. Maybe somebody had a similar project or wants to help me?
    Regards,
    Laura
