RFID-r/rw help
Discussion in 'General Electronics Chat' started by anushka, Dec 12, 2011.
  1. anushka
    May 17, 2008
    I want to use a IFID module to make an access control system to my school project.
    I observed some RFID r/rw transponders(in 125khz range) from internet but those have complex methods to write a tag number to the transponder chip.
    I need only to demonstrate the RFID mechanism by using simple design.Im try to use below IC to my rfid reader circuit.
    http://www.emmicroelectronic.com/webfiles/product/rfid/ds/EM4095_DS.pdf
    I want to know,
    1. What is the easiest transponder type I can use? like,
    EM4105(r/w)
    EM4069(R/W)
    EM4050
    EM4150
    EM4070
    EM4170
    or any other
    2. If 'read/write' transponders easy to handle than 'read only' ?
  2. colinb
    Jun 15, 2011
    351
    35
    Of course the read-only transponder will be simpler since you don't need to program it.
    Do you want to make both the reader circuit and the transponder circuit? Otherwise if you only care to make one side at this point, you can buy some inexpensive RFID tags or a serial-output reader device.
