RFC at the collector leg of transistor
xylon89del
Joined Dec 28, 2011
17
When designing an amplifier or oscillator in common-emitter configuration,
at the collector leg, sometimes the resistor is replaced with inductor?
What is the purpose of replacing the resistor with inductor?
34,432
Higher AC gain. The inductor can be selected to have a higher impedance at the signal frequency than a resistor which gives higher AC gain. The value of the resistor is limited by the required transistor bias current and supply voltage.
radiohead
Joined May 28, 2009
514
Also, when using the (NPN) transistor in an RF application, the inductor (RF choke) will assist in keeping RF from straying off an intended path.
xylon89del
Joined Dec 28, 2011
17
Why cant we just put a resistor which its value is the same as the impedance of the inductor at the specific frequency?
34,432
Because the impedance of the resistor would be too high to carry the desired bias current for the transistor using a normal low amplifier supply voltage.
