RF Wakeup - RFID without the ID
Discussion in 'Wireless & RF Design' started by timpa04, Jul 6, 2014.
  1. timpa04
    Jul 3, 2014
    I'm creating a "keyless" entry system using an nRF24L01+ and an AVR on both sides.
    The base units power consumption isn't a concern, however the keys power consumption is.
    The key will be powered by a CR2032 battery, and I would like to have an average consumption <14 µA.
    I've played around with duty cycles, but I can't get the consumption low enough since every message takes about
    25 ms from wakeup until the message bounces back.
    The only solution I can think of is having another RF module attached which would handle nothing but wakeup.
    It would be perfect if there is something like a passive receiver with a range of 1m-3m which would send an IRQ
    when it receives a signal.
    Do you have any suggestions?
  2. MrChips
    Oct 2, 2009
    12,643
    3,457
    Why would the power consumption of the key be a problem?
    The button on the key is the power switch. Hence the key consumes no power when not being used. If your button is a soft power-on switch, the MCU should be placed into low-power mode for lowest power drain.
  3. timpa04
    Jul 3, 2014
    There won't be any button to push on the key, it's supposed to be what they
    call a keyless system. It will react simply by approaching.
  4. MrChips
    Oct 2, 2009
    12,643
    3,457
    Why make life complicated? Put a button on the key.
  5. timpa04
    Jul 3, 2014
    Great answer. Thank you so much for your help
  6. timpa04
    Jul 3, 2014
    Anyone else?
