rf transmitter/receiver
Discussion in 'The Projects Forum' started by reaxbeats, Mar 27, 2013.
  1. reaxbeats
    Mar 22, 2013
  2. DickCappels
    Aug 21, 2008
    2,746
    665
    That link points to the website's front page. How about the name of the manufacturer and the manufacturer's part number
  3. reaxbeats
    Mar 22, 2013
    1LOT=20pcs=10set 433M RF wireless receiver module
    Receiver module parameters
    Product Model MX-05V
    Operating voltage: DC5V quiescent current: 4MA
    Receiving frequency: 433.92MHZ
    Receiver sensitivity:-105DB
    Size: 30 * 14 * 7mm external antenna: 32CM single core wire, wound into a spiral
    Technical parameters of the transmitter head
    Product Model: MX-FS-03V
    Launch distance :20-200 meters (different voltage different effect) working voltage :3.5-12V Dimensions: 19 * 19mm
    Ways of working: AM transfer rate: 4KB / S transmit power: 10mW
    Transmitting frequency: 433M
    An external antenna: 25cm ordinary multi-core or single-core line
    Pinout from left → right: (DATA; VCC; GND)
    Application environment
    Remote control switch, receiver module, motorcycles, automobile anti-theft products, home security products, electric doors, shutter doors, windows, remote control socket, remote control LED, remote audio remote control electric doors, garage door remote control, remote control retractable doors, remote volume gate, pan doors, remote control door opener, door closing device control system, remote control curtains, alarm host, alarm, remote control motorcycle remote control electric cars, remote control MP3.
    Optional accessories
    Supporting the use of remote control products and company.
    Remark
    VCC voltage module operating voltage and good power filtering; Great influence on the antenna module reception, preferably connected to the 1/4 wavelength of the antenna, typically 50 ohm single conductor, the length of the antenna 433M of about 17cm; Antenna position has also affected the reception of the module, the installation, the antenna as possible straight away from the shield, high pressure, and interference source; frequency used to receive, decode and oscillation resistor should match with the transmitter.
