RF transmitter program
Discussion in 'Programmer's Corner' started by sathishbabug, Mar 15, 2009.
  1. sathishbabug
    Mar 10, 2009
    9
    code to transmit some data using RF TRANSMITTER through 8515 and also to receive the same ....
    i need it in C language
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    How about posting a schematic of your circuit?
    hgmjr
  3. sathishbabug
    Mar 10, 2009
    9
    how to connect a pir re200b to 8515 ...
    code and diagram showing the pins and info
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    I have combined your posts since they are related to each other.
    Do you not have a schematic of your circuit?
    hgmjr
  5. sathishbabug
    Mar 10, 2009
    9
    in theory and also in schematics
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    So can you post what you have so far?
    hgmjr
  7. sathishbabug
    Mar 10, 2009
    9
    sending an attachment showing schematic....
    i need program for PIR to 8515 and then RF program ...
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    Are you planning to code in Assembly Language or C Language?
    hgmjr
  9. sathishbabug
    Mar 10, 2009
    9
    hi.............
    thanks for your help in this..
    i need the code in C language..and
    how to test a PIR RE200B sensor ... i need circuit regarding it and i need the amplifier(indicating gain ) and comparator circuit too ...(second block )
    program to interface that output of comparator to atmega 8515..
    program to transmit that using RF Tx of 433 Mhz...
    program to receive that data using RF Rx of same frequency..
    program to interface 8515 to a alarm ...
    need a schematic showing the connection pins of each and every block .. i mean what ports are used and which pin in that in detail...
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That is not a schematic - it is a block diagram. In essence, you are asking us to do the complete project for you, and provide you with all the details.
    Why are you unable to do any of this work?
  11. sathishbabug
    Mar 10, 2009
    9
    actually we have to submit all these things in 2 days and we are not getting any correct information and our lecturers also denied us to help.so,it is finally u to help us. with a gr8 hope i am replying this.
    i wish that u shall help us......
