RF Transmitter interfacing with PIC16F877a
Discussion in 'Radio and Communications' started by saseendranath, Feb 15, 2014.
  1. saseendranath
    Feb 15, 2014
    how i could verify my micro c code for transmitting a signal?
    iam using RF Transmitter and Receiver.
    proteus for simulation and micro c for hex file generation.
    what is the use of UART terminal in proteus?
    could anyone help me
    Iam trying to send a code wirelessily to run a motor and a counter.
    i had done almost half and verified the simulation.
    remaining is the transmission part.
    Iam using 433MHz ASK OOK transmitter, pic16f877a microcntroller
  2. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    You can put your wireless module on a USB port (with a suitable convertor) and use the COMII port module to talk to it....
    I use XBee module... You buy a little USB connector to mount the XBee unit in and Proteus can access the rf module....
  3. AfdhalAtiffTan
    Member
    Nov 20, 2010
    117
    11
    THE_RB likes this.
  4. saseendranath
    Feb 15, 2014
    how could we use 2 pairs of RF transmitters and receivers of same frequency simultaneously? i found a problem while transmitting back a signal
