Actually Maxwell's equations make this an extremely challenging proposition. In short, any changing electric filed produces a magnetic field; and any changing magnetic field produces an electric field. Since these are VECTOR fields the word "change" applies to BOTH the magnitude AND the direction. The process of modulation implies change, so I would have to say that if it were possible there would be NO information in the signal.Hi.
Could a 10 MHz RF signal propagate only with its magnetic field and without its electric field, from/to a 'ferrite' type of antenna ?
-Say the RF electric field is severely attenuated by the propagation medium, but its magnetic field is not-
Hi,Hi.
by Jake Hertz
by Jake Hertz
by Duane Benson
by Jake Hertz
