RF transmiiter & Receiver control by PIC16f877a
Discussion in 'Embedded Systems and Microcontrollers' started by ibnusabr, Jan 17, 2009.
  1. ibnusabr
    Jan 17, 2009
    actually my project want to transmitter the data using RF module (www.cytron.com.my). i will fabricate 2 circuit(a & b). each circuit has RF transmitter, RF receiver,PIC16F877a, LCD display. after done the fabrication, the circuit a cannot send the data to the circuit b and vice versa. plZZ help me check this program..
    void ePulse ( void );
    void LCDInit ( void );
    void LCDAdd ( unsigned char );
    void LCDWrite ( unsigned char );
    void LCDStr ( unsigned char * );
    void LCDClr ( void );
    void Usart_Write(unsigned short data);
    void usart(void);
    void Usart_Init(const unsigned long baud_rate);
    unsigned short Usart_Read(void);
    unsigned short Usart_Data_Ready(void);
    unsigned char msg_welcome0 [17] = "NEIGHBORHOOD";
    unsigned char msg_welcome1 [17] = "WARNING SYSTEM";
    unsigned char msg_0 [17] = "HOME A NEED HELP";
    unsigned char msg_1 [17] = "HOME B NEED HELP";
    unsigned char msg_2 [17] = "HOME C NEED HELP";
    unsigned char msg_3 [17] = "HOME D NEED HELP";
    unsigned short Button(unsigned short *port, unsigned short pin, unsigned short time,
    unsigned short active_state);
    unsigned char oldstate;
    int num;
    int main (void)
    Delay_ms(1000);
    TRISB=0x0F;
    PORTB=0x00;
    TRISC = 0b10000000;
    PORTC = 0b10000000;
    LCDInit ();
    LCDClr ();
    LCDAdd ( 0x0 );
    LCDStr ( msg_welcome0 );
    LCDAdd ( 0x40 );
    LCDStr ( msg_welcome1 );
    PORTB=0x0f;
    Usart_Init(1200);
    do {
    if (Button(&PORTB, 0, 1, 1)) oldstate = 1;
    if (oldstate && Button(&PORTB, 0, 1, 0)) {
    num = 1;
    Usart_Write(num);
    LCDClr ();
    LCDAdd ( 0 );
    LCDStr ( msg_0 ); //LCD display "HOME A NEED HELP"
    oldstate = 0;
    PORTC = 0b10000001;
    if (Usart_Data_Ready()) { // If data is received
    num = Usart_Read(); // Read the received data
    if ((num==1) || (num==2)||(num==3)||(num==4)) ;
    if (num==1)
    LCDClr ();
    LCDAdd ( 0 );
    LCDStr ( msg_0 ); //LCD display " HOME A NEED HELP "
    PORTC = 0b10000001;
    else if(num==2)
    LCDClr ();
    LCDAdd ( 0 );
    LCDStr ( msg_1 ); //LCD display " HOME B NEED HELP’’
    PORTC = 0b10000001 ;
    else if(num==3)
    LCDClr ();
    LCDAdd ( 0 );
    LCDStr ( msg_2 ); //LCD display " HOME C NEED HELP "
    PORTC = 0b10000001;
    else if (num==4)
    LCDClr ();
    LCDAdd ( 0 );
    LCDStr ( msg_3 ); //LCD display " HOME D NEED HELP "
    PORTC = 0b10000001;
    else
    PORTC = 0b10000001;
    else if(Button(&PORTB, 1, 1, 1)) oldstate = 1;
    if (oldstate && Button(&PORTB, 1, 1, 0)) {
    num = 0x02;
    Usart_Write(num);
    LCDClr ();
    LCDAdd ( 0 );
    LCDStr ( msg_1 ); //LCD display " HOME B NEED HELP "
    oldstate = 0;
    PORTC = 0b10000001;
    num = Usart_Read();
    PORTC = 0b10000001;
    if (num==1)
    LCDClr ();
    LCDAdd ( 0 );
    PORTC = 0b10000001;
    else if(num==2)
    LCDClr ();
    LCDAdd ( 0 );
    else if(num==3)
    LCDClr ();
    LCDAdd ( 0 );
    PORTC = 0b10000001;
    else if (num==4)
    LCDClr ();
    LCDAdd ( 0 );
    PORTC = 0b10000001;
    else
    PORTC = 0b10000001;
    else if(Button(&PORTB, 2, 1, 1)) oldstate = 1;
    if (oldstate && Button(&PORTB, 2, 1, 0)) {
    num = 3;
    Usart_Write(num);
    LCDClr ();
    LCDAdd ( 0 );
    oldstate = 0;
    PORTC = 0b10000001;
    num = Usart_Read();
    PORTC = 0b10000001;
    if (num==1)
    LCDClr ();
    LCDAdd ( 0 );
    PORTC = 0b10000001;
    else if(num==2)
    LCDClr ();
    LCDAdd ( 0 );
    else if(num==3)
    LCDClr ();
    LCDAdd ( 0 );
    PORTC = 0b10000001;
    else if (num==4)
    LCDClr ();
    LCDAdd ( 0 );
    PORTC = 0b10000001;
    else
    PORTC = 0b10000001;
    else if(Button(&PORTB, 3, 1, 1)) oldstate = 1;
    if (oldstate && Button(&PORTB, 3, 1, 0)) {
    num = 4;
    Usart_Write(num);
    LCDClr ();
    LCDAdd ( 0 );
    LCDStr ( msg_3 ); //LCD display "keadaan bahaya"
    oldstate = 0;
    PORTC = 0b10000001;
    num = Usart_Read();
    PORTC = 0b10000001;
    if (num==1)
    LCDClr ();
    LCDAdd ( 0 );
    PORTC = 0b10000001;
    else if(num==2)
    LCDClr ();
    LCDAdd ( 0 );
    else if(num==3)
    LCDClr ();
    LCDAdd ( 0 );
    PORTC = 0b10000001;
    else if (num==4)
    LCDClr ();
    LCDAdd ( 0 );
    PORTC = 0b10000001;
    else
    PORTC = 0b10000001;
    while (1);
    // LCD CONFIGURATION
    PORTE |= 0x2;
    Delay_Cyc(1);
    Delay_Cyc(1);
    Delay_Cyc(1);
    PORTE &= 0xfd;
    Delay_Cyc(1);
    Delay_Cyc(1);
    Delay_Cyc(1);
    ADCON1 = 0xe;
    PORTD = 0;
    TRISD = 0;
    PORTE = 0;
    TRISE = 0;
    PORTD = 0x38;
    ePulse ();
    Delay_us(40);
    PORTD = 0x0c;
    ePulse ();
    Delay_us(40);
    void LCDWrite ( unsigned char data )
    PORTE |= 0x1;
    PORTD = data;
    ePulse ();
    Delay_us(40);
    PORTE &= 0xfe;
    void LCDStr ( unsigned char * data )
    unsigned char num = 0;
    while ( data [ num ] )
    LCDWrite ( data [ num ] );
    num++;
    PORTD = 0x1;
    ePulse ();
    Delay_ms(2);
    void LCDAdd ( unsigned char data )
    PORTD = 0x80 + data;
    ePulse ();
    Delay_us(40);
    plZZZ help meeee...
