RF transformer and IF transformer
Discussion in 'General Electronics Chat' started by jasonhaykin, Apr 17, 2007.
  1. jasonhaykin
    Mar 8, 2007
    23
    Hi guys,
    Please tell me about IF transformers and RF transformers.
    I just don't know anything about them. :confused:
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    They are transformers. They are characterized to work at higher frequencies than power transformers. They are used for coupling and impedance matching.
  3. recca02
    Apr 2, 2007
    1,211
    wiki describes rf transformer as
    "For radio frequency use, transformers are sometimes made from configurations of transmission line, sometimes bifilar or coaxial cable, wound around ferrite or other types of core. This style of transformer gives an extremely wide bandwidth but only a limited number of ratios (such as 1:9, 1:4 or 1:2) can be achieved with this technique.
    The core material increases the inductance dramatically, thereby raising its Q factor. The cores of such transformers help improve performance at the lower frequency end of the band. RF transformers sometimes used a third coil (called a tickler winding) to inject feedback into an earlier (detector) stage in antique regenerative radio receivers."
  4. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    And an IF transformer is just an RF transformer tuned to the IF frequency... ie 10.7 MHz, or 455KHz or whatever happens to be used.
  5. mozikluv
    Jan 22, 2004
    1,437
    and i might add wide band rf trannys application are for matching impedance, voltage/current transformation, dc isolation, power splitting, signal inversion, likewise balance/unbalanced mixing.
    there's this custom wide band trannys that has special combination of impedance ratio, also frequency response, just to mention a few.
    you should also check the very informative tutorial in this site.
    moz:)
  6. jasonhaykin
    Mar 8, 2007
    23
    Thanks guys.
