Rf transceiver circuit to run a buzzer
Discussion in 'The Projects Forum' started by kanha, Aug 18, 2011.
  1. kanha
    Jun 30, 2010
    Hi guys and gals
    I am in urgent need of you help:D. My aim is to run a buzzer:eek: whenever a switch is pressed is pressed in the transmitter circuit. I am using Rx/Tx 434 as rf transceive:confused:. Now I am using Ht 12d/Ht 12e to serve as rfid tags. The problem is I am not getting any output in my leds(test sample). I am attaching the circuit diagrams below. I am using 820kohms instead of 750kohms in ht12e. For the antennas I am using about 5cm of uninsulated copper wire(with a round solder bead at the top) as the two of them are in the same breadboard. The battery is 9v converted to 5v using lm7805. Please let me know any/all mistakes at the earliest. There is one small difference in the transceiver chips. The rx and tx 434 I am using has the pins labelled in say a different fashion compared to the circuit.
    cp:)
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    Wireless door buzzers are available at your local hardware store.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    Yes , one can see that on the breadboard picture, please post a datasheet of the RF-modules you are using. How can they have different pinouts?
    Decoder frequency should be around 50x encoder frequency, if you use 33k in the decoder circuit you'll have about 60x, I don't know if that matters, I don't think so.
    Do all adress lines have the same voltage level (0 in the diagram)?
    If you have an oscilloscope, measure the data out of the encoder when pressing the /TE button (is it pulling /TE to LOW?).
    If there is data then measure the data out of the receiver circuit.
    Post your findings (as detailed as possible)
