rf receiver transmitter
Discussion in 'The Projects Forum' started by jimit, Dec 22, 2010.
  1. jimit
    Oct 28, 2010
    57
    hi every one i am making a RF car i have a 434 MHz RF module receiver and transmitter can some one suggest me some circuit for it. it should be a four Chanel one plz
    i tried googling but ended with nothing :D
  2. Kermit2
    Feb 5, 2010
    3,847
    963
  3. jimit
    Oct 28, 2010
    57
    i had a look and it seems well but which transistor shall i use some number or code must be there ????
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    I hope you realize that will give you on/off control, not proportional. In other words, steering will be full left or full right, and so forth.
    You also will need an interface to use servos.
    John
  5. jimit
    Oct 28, 2010
    57
    i am not using servo motors i will be using four 12v,200rpm gear motor
    which will give me a tank motion (the 360 0ne) :D
  6. jimit
    Oct 28, 2010
    57
    can i use the TIP30 transistor
  7. jpanhalt
    Jan 18, 2008
    5,699
    909
    Sure, what do you plan to use it for?
    John
