RF Power Amplifier
Discussion in 'The Projects Forum' started by waqashussian86, Jul 27, 2010.
  1. waqashussian86
    Jul 27, 2010
    I am an Electronics Engineer and I am working on my final year project Wireless Power Transmission System. Friends I need your help I need a 3 Watt linear RF Power Amplifier which can operate at a frequency range from 1 MHz to 3 MHz. Please send me its design or the schematic diagram with detailed components specifications as soon as possible. If anybody who is electronics circuit designer and could design it so kindly helps me.
    Regards,
    Syed Waqas Hussain
    Electrical Engineer
    <snip>
  2. tom66
    May 9, 2009
    2,613
    214
    We cannot do all your work for you; we can only help. After all, it wouldn't be your work if someone else designed it.
    Are you sure about 1MHz to 3MHz. First, that's a rather large range for such a low frequency, second, it's going into the AM broadcast band (and possibly other allocations!) and without a costly license fee, proper certification and training, you cannot broadcast in this band.
  3. windoze killa
    Feb 23, 2006
    605
    24
    If we do the work do we get a degree as well?????:D
  4. gootee
    Apr 24, 2007
    447
    50
    If your project is "Wireless Power Transmission" and not "Designing an RF Power Amplifier", why don't you just use an existing amplifier?
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    I found this page with some old application notes on power amplifiers:
    http://www.communication-concepts.com/application_notes.htm
    Most run from 1.6 Mhz as they are written for HAM's.
    Bertus
    PS keep in mind to check the regulations in your area for transmitting at the frequency range.
