RF Oscillator from scratch
hersheybenjamin
Joined Dec 23, 2010
I am seeking to make an FM transmitter totally from scratch. By "from scratch", I mean not using any pre-made circuits or any doped semiconductors. I just want to use wire, batteries, etc. So basically my question is: Is it possible to make a sine wave oscillator without the use of any transistors or amplifiers? Capacitors, inductors, etc. are no problem, but I can't make doped silicon from scratch. So the oscillator would not be able to include: transistors, amplifiers, diodes, inverters, etc. Is this possible? Any help would be greatly appreciated. :) Thanks!
Wendy
Joined Mar 24, 2008
23,421
You could, but it would not be legal. You have entered the realm of arc gap transmitters, where an arc across a tank circuit generates RF.
As for modulation, forget it. This type of generator (it is not an oscillator strictly speaking) splatters all over the spectrum.
For clean signals, an active device is required.
DickCappels
Joined Aug 21, 2008
10,171
Then you might want to make your own zinc negative resistance diode, which is a home made semiconductor that can be used to make an oscillator. This can probably get you up to several MHz, though you might get lucky and make a VHF device.
This link takes you to a demonstration of such a transmitter:
http://www.youtube.com/watch?v=cDBpBYkRw0Q
This link tells you how to make your own diode out of sheet metal and shows some application circuits:
http://home.earthlink.net/~lenyr/zincosc.htm
This link contains a video showing a negative resistance diode being made and an 80 meter transmitter circuit:
http://brainwagon.org/2008/12/05/zinc-negative-resistance-80-meter-cw-transmitter/
Here is the web page for that 80 meter transmitter:
http://sparkbangbuzz.com/zinc-osc-2/zinc-osc3.htm
