RF LED question
Discussion in 'The Projects Forum' started by Electrodiode, Oct 18, 2008.
  1. Electrodiode
    Oct 18, 2008
    Hello i was wondering how i could transmit a signal to a receiver to tell a LED to light up? Thats basically the question. The whole project is this, to build a laser alarm system. I already know how to set up the laser system i want build. That was the simple part but how would i lest expensively build a system where when the laser is broken it transmits to a receiver turning on LED. And i would like for the transmitter range to be able to cover an acre.
    thanks any ideas will be great.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    To use a transmitter, you usually have a press-to-talk switch. Arrange your laser trip wire to do the same function.
    The receiver usually has a squelch function that requires a receipt of the transmit signal. Often, the squelch signals the receipt of the transmitted signal by turning on a LED.
    Depending on the frequency and terrain, 100 mv of RF should give the coverage. Check on some inexpensive walkie talkies from Radio Shack.
  3. DickCappels
    Aug 21, 2008
    2,777
    674
