RF isolation
Discussion in 'Wireless & RF Design' started by Will777, Oct 6, 2010.
  1. Will777
    Sep 12, 2010
    48
    I am struggling to get a good reading using a RF sniffer/Frequency counter for a FM transmitter - could it be that it's also picking up other RF emissions?
    If that is the case, what DIY method can I use to build an RF isolation chamber so I can get accurate readings for the frequency counter?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. Will777
    Sep 12, 2010
    48
    I've thought of that, but I was thinking that there must be an easier way to shield RF, like aluminium foil or something?
  4. Kermit2
    Feb 5, 2010
    3,852
    968
    Maybe a direct coupled connection would be better. try a 10 pf and 1 meg resistor and lower the resistor value if the counter doesn't get enough signal.
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The best is to mount the RF amplifier inside a metal box.
    I made a photo of an example of an RF amplifier I have here.
    Bertus
    Will777 likes this.
  6. Will777
    Sep 12, 2010
    48
    Thanks, but this is not measured through an RF sniffer that connects to the antenna position on the circuit, it's a separate device with a telescopic aerial that measures RF output and determines frequency
  7. Will777
    Sep 12, 2010
    48
    Dankie Bertus. I will definitely try that.
