RF Energy
Discussion in 'General Electronics Chat' started by Mazaag, Sep 4, 2007.
  1. Mazaag
    Thread Starter Senior Member
    Oct 23, 2004
    255
    Hi guys,
    I have seen alot of different medical devices that say they use RF energy to perform ablation or lesions using probes that they insert to the target area.... my questions are as follows.. what exactly is "RF Energy" , and how is it possible for it to cause heat (for ablation i'm pressume) using a probe ? and
    secondly, what are the effects of a) Voltage and b) Current on human tissue
    thank you
  2. niftydog
    Jun 13, 2007
    95
    RF = radio frequency. Think "microwave oven" and you're half way there. Microwaves cause water molecules to vibrate, causing friction, which generates heat.
    Voltage by itself doesn't do much to tissue except for maybe slightly polarising molecules, as far as I'm aware. You can be "floating" at very high voltages without any ill effects. But the current is the thing that you want to look out for. Current passing through tissue causes burns, but more importantly, even a tiny current passing through your heart can cause arrhythmia which can kill you.
  3. Mazaag
    Oct 23, 2004
    255
    still not 100% sure on that...
    So when we have RF waves for in a medium... do we have voltages and current ? or do we have electrical and magnetic fields? or both ? like does there exist an electrical and magnetic field ( part of the EM wave ) that give rise to voltages and currents in media ? and if so , do these currents give rise to heat ? and is it possible to cause arhythmiya using EM wave radiation ?
    i'm kinda lost lol
  4. niftydog
    Jun 13, 2007
    95
    Well, microwaves are EM waves - as are light, heat, UV, gamma rays etc etc. Electric and magnetic field co-exist - magnetic fields are created by moving electric charges , or in other words, current flow. Current encountering resistance causes heat and voltage.
    As for EM waves causing arrhythmia, well yes they do in a sense, but that's because a current flow of any type is accompanied by EM waves. Are you asking about an external RF energy source powerful enough to generate sufficient current flow in your heart? If so, I think the LEAST of your worries would be arrhythmia! Imagine putting yourself inside a microwave oven and turning it on - would you be more worried about a heart palpitation or being cooked?!
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Whilst true for microwave frequencies, at RF frequencies Joule heating is an increasingly important component for the overall heating because the polar molecules are better able to realign to the applied field.
    Propagating EM waves have both electric and magnetic field components (Maxwell's Equations), and within the workload (tissue) you will experience voltages and currents dependant on the electric and dielectric properties. Heat specifically generated through current flow is Joule heating (as stated above). If you are looking at understanding how EM waves heat biological tissues you should look at a subject called 'Dielectric Heating' -this is a very complex and poorly understood subject, so you should have some interesting questions arise from your study.
    Dave
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Wikipedia has an article on the subject - http://en.wikipedia.org/wiki/Cauterization. I don't know where the dividing line between AC and RF has been set, but the 100 KHz of the electrocautery equipment is definitely in the RF region.
    One of the effects that protects the patient is called skin effect. This has nothing to do with animal tissue, but refers to the tendancy of RF currents to stay in the vicinity of the outer layer of the conductor, When things are really high in frequency, you turn the wire inside out and it becomes waveguide.
    I'm not sure that 100KHz is really high enough for significant skin effect, but it may contribute to keeping the current confined to the immediate area where the electrocautery is being performed.
  7. JoeJester
    Apr 26, 2005
    3,403
    1,229
    I think the RF region begins much lower than 100kHz. IEEE C95.1 is titled
    One of the Omega Navigation System frequencies was 10.2 kHz.
  8. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    I've had it done to remove a wart. The doctor grounded my hand and then used a probe to burn out the wart. She went pretty deep to. It's just a high frequency, high voltage supply though I'm not sure of the current.
  9. mOOse
    Member
    Aug 22, 2007
    20
    beenthere was pointing out that there is no frequency dividing
    line between AC and RF, but that 100k is clearly RF.
    But AC and RF are simply different things, aren't they?
    AC is an alternating current in a conductor which may cause
    em oscilations, which would be RF waves at AC frequency.
    Also, in theory couldn't you have a 100k AC source?
    Is there any special purpose to which it might be suited,
    or is it simply insane?
    Code ( (Unknown Language)):
    1.
    2.                         RF Frequency Bands (Hz)
    3.       ------Low Frequency--------------------High Frequency-----
    4.       ELF  SLF  ULF   VLF   LF    MF    HF   VHF   UHF  SHF  EHF
    5. Lower   3   30  300    3k   30k  300k   3M   30M  300M  3G   30G
    6. Upper  30  300    3k  30k  300k    3M  30M  300M    3G 30G  300G
    7.
    8. (E)xtremely, (S)uper, (U)ltra, (V)ery, (L)ow, (M)edium, (H)igh
    9.
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    For what its worth: In Tomography (and dielectric heating applications), we consider RF frequencies to be from 3Hz to 500MHz, and microwave frequencies to from 500MHz to 300GHz (I have seen the RF-microwave boundary stated as 300MHz and 1GHz before). This is by no means a standard, but is the generally accepted ranges stated in publications and literature on the subject.
    Dave
  11. gmrkiran
    Sep 11, 2007
    8
    i want no basics of vhf and uhf
