RF circuits help
Discussion in 'The Projects Forum' started by schall92, Nov 29, 2012.
  1. schall92
    Nov 29, 2012
    Hi I'm doing some research on radio frequency circuits in hopes of playing around with them a little. Whenever, I see a basic RF circuit, especially AM circuits, there are always transistors. Are those for amplification purposes only or is there some other use for them in the network? Could I substitute an amplifier IC for the transistor and its accompanying components? (resistors and capacitors) Thanks.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    depending on the arrangement they are also used for the modulation...
  3. schall92
    Nov 29, 2012
    Do you know how they are used for that?
  4. tshuck
    Oct 18, 2012
    3,531
    675
  5. vk6zgo
    Jul 21, 2012
    677
    85
    I suggest you have a look through the ARRL Handbook or something similar.
    Transistors (both BJTs & FETs) are widely used in RF circuits,as are ICs.
    The ICs used at RF are often specially designed for such frequencies,& using a standard Op Amp or similar,may yield disappointing results.
    Some RF beginners on this forum seem to get hung up on low frequency design & construction methods which don't work well at higher frequencies.
    Also,many "example" circuits which appear on the 'Net are merely to illustrate concepts,& do not lend themselves to practical use.
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Even in a receiver there are transistors that are used as oscillators to provide various useful functions. Learning to read datasheets is the key to understanding what you can and cannot do with a component. A serious study of RF engineering includes the acquisition of a deep understanding of passive AC circuits involving inductors and capacitors. A little algebra of complex numbers never hurts either. You can hold of on the calculus and differential equations for a while, but not forever.
