RF Capacitors.
Discussion in 'Wireless & RF Design' started by sidchel2, May 13, 2011.
  1. sidchel2
    May 13, 2011
    I have a Plessey 0.05 Mf 2.5 KV part No 436/1/22010/130 can someone please tell me if this is suitable for use with RF? I also have some E-472 3KV ceramic disc caps are these also suitable for RF use?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What are your concerns? Have you looked at the manufacturer's specs?
  3. sidchel2
    May 13, 2011
    I am building a Linear amp and the caps are for use in the Rf input to the amp and the decoupling on the HT input. I cant seem to find any information on the caps that I have.
  4. radiohead
    May 28, 2009
    474
    31
    In general, here are some typical capacitor characteristics.
    Ceramic: 1pF to 22pF - Filtering, Bypass
    Mica: 1pF to 1uF - Timing, Oscillators
    Metal Foil: up to 100uF - DC Blocking, Filtering
    Polyester: .001uF to 100uF - Timing, Tuning
    Polystyrene: 10pF to 10uF - Timing, Tuning
    Paper Foil: .001uF to 100uF - General Purpose
    Tantalum: .001uF to 1,000uF - Bypass, Coupling, DC
    Aluminum: 10uF to 220,000uF - Filtering, Bypass
