Hello!
I've got an old, cheapish diesel generator that is pull start. I'd like to make it electric start as it is destined to replace a large BMC 2.2 diesel in our boat and will therefore not be in pull range. After reading and reading I came across this post
"If you know a guy who can do motor controls, all you need is a 12v battery and a couple inexpensive relays and a little time and you can turn the AC motor into a DC Shunt motor if there is access to the Terminal Tap Can. This is how most old generators were started. It turns the Electric Generator into a motor temporarily and switches back to a generator after the motor is started. It is an easy install within the hour."
That was here: http://bit.ly/GATEP8
I've emailed the poster for diagrams or further information with no reply. I've been doing a little digging into the original 'self-start motor' the predated the modern starter motor and it seems that on the outset I could use my electric motor to turn over my diesel.
Is this possible and does anyone know about a wiring an 'AC motor into a DC Shunt Motor'? I'd appreciate the help.
Thanks!
Nathaniel
Thanks!
Nathaniel
