Reviewing the LM723
Discussion in 'General Electronics Chat' started by hp1729, Dec 2, 2015.
  1. hp1729
    Nov 23, 2015
    2,085
    232
    Sure, it is ancient. You can stock a bunch of more modern voltage regulators or you can just stock one that does positive or negative, low current or high current with just adding a cheap power transistor. Nonetheless the LM723 has some great lessons on how voltage regulators work. Operating voltage goes up to about 37 V. Not a bad deal for about $0.50 US. Old, yes,, but still very educational and useful.
    The LM723 has two basic sections. It has a voltage reference section and a regulator section. The reference section puts out about 7 Volts. Absolute Maximum Rating on the spec sheet says 15 mA, maximum to be drawn. From 1 mA to 15 mA this output probably won't waver even 1 mV. The voltage regulator section can tolerate about 150 mA being pulled from it. Adding an external transistor adds to this. Most any transistor will do.
    For operation below 7 Volts a voltage divider is added to the output of the voltage reference. The Voltage regulator section compares this voltage to the output voltage. For operation above 7 Volts you put the voltage divider on the output and compare the 7 V reference against a tap at 7 Volts on the divider.
  2. hp1729
    Nov 23, 2015
    2,085
    232
    Schematic examples. The LM723 is shown broken down into its inner parts for educational purposes.
  3. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,844
    1,309
    FWIW I'm partial to the LM338 (and it's ilk) for it's all around superior characteristics...
    I offer a single caveat in regards to such devices -- Although promoted as 'adjustable regulators' ('programmable regulators' would seem more apt) one must exercise extreme caution when applying same to adjustable PSUs --- Stray outside the (less than intuitive) boundaries of the 'safe area' and your PSU output will resemble that of a malfunctioning sawtooth generator!:eek::eek::eek:
    That said - IMNSHO properly applied linear regulation is the only choice where ultra low noise performance is required:)
    Best regards
    HP
  4. AnalogKid
    Aug 1, 2013
    4,685
    1,297
    For a normal-sized benchtop device, absolutely. But for an application-specific power system, not so much.
    At one time there were four companies in the US that made MRI scanners, and my company built sub-systems for three of them. One customer was moving to an upgraded design, and had a big SWaP (size, weight, and power) problem. A rackmount chassis with two 6U card cages had two multi-output switchers and four large single-output linears (two of them quite large), in the theory that they needed linear supplies for their low-noise signal processing section. I re-spun their signals backplane to have two small linear regulators to take POL regulators (and their heat) off one of their boards, and sprinkled frequency-specific decoupling at all backplane slot connector power pins, increased the power levels of both switchers, and powered the signals backplane directly off of them. Results, it reduced the chassis height by 3U, reduced weight by 30 pounds, reduced system power by 15%. But about the noise - it was less than 3 mV p-p at 100 MHz bandwidth, 4x below their previous best design, and 8x below their internal design spec. They had to rent a high performance test platform to measure it.
    Why? Because while their linear supplies measured very well, they did not have 60 MHz decoupling at their outputs. And even if they had, the feet of wire to the backplane were excellent loop antennae. The majority of their interfering noise was radiated and conducted from the 1200 W of digital banging in the other card cage.
    IMELHO properly applied switching supplies are an excellent choice where ultra low noise performance is required.
    BTW, IMESHO MNSHO is ELH (even less humble) than yours, so there.
    ak
  5. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    An interesting observation and very compelling point!:)
    Re: noise benefits of linear regulation
    ---Emphasis added---
    Bearing the previous quotation in mind --- Granted!:):):)
    Very best regards
    HP
  6. hp1729
    Nov 23, 2015
    2,085
    232
    All very wise words. No, I am not suggesting the LM723 for new commercial devices. It is a suitable solution for education or home tinkering.
    Hypatia's Protege likes this.
  7. #12
    Nov 30, 2010
    16,665
    7,313
    FWIW, I'm partial to the LM723 because that's what I cut my teeth on. Those years of experience allowed me to develop some versatility and I especially admire the ability of the chip to protect itself from excessive loads. When the company hired a, "real" engineer, his three pin regulator designs sounded like popcorn when subjected to the tests I used on my LM723 designs. Of course, that was AFTER I showed him how to find the limit on how many turns you can fit inside a torroid.:D
    Some ten years later, I was denied a job designing an oven to temperature cycle new products because I was only a State Certified designer of heating and cooling machines. The, "real" engineer who got the job designed a machine that melted $3 million worth of products on its first run. I have the photograph.;)
    I have virtually worshiped some great engineers during my career, but claiming you're a, "real" engineer doesn't impress me; your designs do. Our colleges are presently turning out thousands of, "real" engineers that couldn't design a clothes dryer without an Arduino in it, and they often struggle to do that because they don't know how to use a bjt as a switch or how to get a microcontroller chip to fire a triac!:mad:
    /end rant
    R!f@@, Sinus23, Lestraveled and 2 others like this.
  8. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    Don't be a tease! -- We're all dying to see the carnage!:D:D:D:)
    Best regards
    HP
    #12 likes this.
  9. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    Fair enough!:) --- I was merely reminiscingo_O
    Best regards
    HP:)
  10. #12
    Nov 30, 2010
    16,665
    7,313
    Something like this?
  11. #12
    Nov 30, 2010
    16,665
    7,313
    Arrrgh! I know where the photo is, but I haven't been able to get my scanner to work since Vista achieved, "Service Pack 2".:(
  12. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    Aye - What would the world be without Microsoft's downgrades:mad:
    Perhaps you could take a 'snap' of it with a camera or CP?:)
    Best regards
    HP:)
  13. #12
    Nov 30, 2010
    16,665
    7,313
    Great idea! I have a PHD (press here, dummy) and it downloads with a USB cable!
    Fail! I have the 1985 Paradyne Corporation Calendar wherein I won the February page with Mount Rushmore and the Cover Shot with a time lapse of the Snake River. I can't find the other calendar with a room full of melted modems for the cover shot.:(
    Please forgive the flash hole. It's a photo of a photo inside a glass frame.
  14. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    You mean to say that they advertised their blunder?! -- And just when I'd abandoned all hope of corporate integrity!:confused::eek::D
    Best regards
    HP:)
  15. #12
    Nov 30, 2010
    16,665
    7,313
    Never fear. There was no integrity intended. The $3M fail was the last straw. They continued for another year by paying their employees in worthless, "stock", then parachuted out with all the pensions and profit sharing disappearing like a politicians promise.
  16. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    How did they manage to destroy $3 million worth of product prior to realizing they had a problem?:confused: I'm thinking Big oven or bad QC???:eek::eek::eek:
    Best regards
    HP
  17. #12
    Nov 30, 2010
    16,665
    7,313
    They hired a, "real" engineer! Real college degree = State of the Art Design, don't you know? Real engineer, big oven, and not a fail-safe in sight...not even a human watching the first full load, 24 hour run. Better to hire a college graduate than a blue collar person with 15 years experience and a State Certification to prove it. Real Engineers don't make mistakes like that, so there is no need to pay anybody to monitor the progress.
    /sarc off
  18. Hypatia's Protege
    Mar 1, 2015
    2,844
    1,309
    But pay they did!:D:D:D
    Best regards
    HP:)
    #12 likes this.
  19. MrAl
    Jun 17, 2014
    2,551
    514
    The 732 went out of vogue a while ago because of its limitations and old method of voltage regulation.
    Back then in the 1970's, it was probably impossible to find a voltage regulator chip WITH a band gap voltage reference. These days it's hard to find one WITHOUT a band gap reference.
    Once the band gap references came in, the zener based references went out. That's because they are better over a wider temperature range.
    Another drawback is the basic required voltage level. If you have a 7v zener then you need at least a 9v supply or so. If you dont have that, you cant use the 732.
    One thing in its favor is the fairly simple current limit, but after all it does have a very wide variation over temperature because it uses the shunted base emitter diode scheme to limit current, and we all know the variation of base emitter diodes over temperature. Luckily, many applications dont need precision current limiting, not even Li-ion as long as there can be some reasonably safe max.
    Also, it's only good for lower currents without added external devices.
    One of the supplies i have is a switcher with a linear output. That's about the best you can get for low noise and clean output with high efficiency as well. But switchers also put out some EMI which can bother some designs.
    #12 and Hypatia's Protege like this.
  20. #12
    Nov 30, 2010
    16,665
    7,313
    Not a problem. I was blowing 35 amps per polarity through my linear designs in 1974, and the foldback circuit still worked!
    It was about as fun and primitive as working with LM555 designs. Both chips have better versions available now, but the education is still applicable. (See my blog for a design that goes from zero volts to 1000 volts, based on the principles available in the LM723 datasheet.)
