Hi all,
Just wondering if it is possible to reverse the output of a rotary encoder via the wiring (as opposed to physically turning the unit 180 degrees)? I have one from a scroll wheel in a mouse which has 3 pins and it's metal body is connected in the original circuit board to the central pin. I tried swapping the two outermost connections in the row of three main pins but then it didn't work at all
