Reversing relay for motor
Discussion in 'The Projects Forum' started by spinicker, Jan 5, 2010.
  1. spinicker
    Jan 5, 2010
    i would like to do something similar with this diagram, but i would like the motor to oscillate continuously from end to end when voltage source is connected and stop when the voltage source is disconnected (by means of a simple spst toggle, most likely). i have already built a unit from a diagram i pulled up on google images, that unfortunately did not work (i didn't read far enough into the source threads to find out that it is faulty). i have trouble going through the diagrams myself to determine if they will work.
    will the diagram in this thread work for my purposes if the trigger is removed and replaced with a direct connection? any help would be greatly appreciated
    nick
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
