I am trying to reverse polarity for a 12V actuator by using SPDT relays. Is it possible to operate the actuator in both directions by using a SPST switch???
Thanks!
Jeff
Thanks!
Jeff
Maybe he wants to control this by a means of control circuit and not by hand but he can still use a DPDT relay instead of two SPDT relays.I controlled the direction of a 12v actuator by using a DPDT center-off switch. I don't know how the forumn posts electrical schematics or I would draw it out for you, assuming you can use a DPDT switch instead of a relay.
Thanks. I'm new hereMaybe he wants to control this by a means of control circuit and not by hand but he can still use a DPDT relay instead of two SPDT relays.
To post a circuit you can convert it to PDF or take a snapshot of it and attache it here (there is an attachment clip above). I don't suggest you to just save it and post the file because the OP, who wants to see it, may not have the same design software as you.
Welcome to the forum thenThanks. I'm new here
If the limit switch can handle the current of the actuator and the circuit voltages then you can use it in the place of relay3.I must use a spst switch i know it would be much easier using a dpdt or even a spdt switch. Would I still need to use a 3rd relay even if i am going to use a limit switch to stop the actuator?
If you look at SGts diagram, it is the relay contact in the center (where the motor is connected on).I am making a tilting pump for a jet ski that tilts vertically. I just have an actuator that is used to tilt the jet now i just need to fiqure the electrcial part out... sorry MIK3 what do you mean by relay 1 or 2 common??
by Jerry Twomey
by Jake Hertz
by Duane Benson
by Jake Hertz
