Reversing polarity to a coil electronically
Discussion in 'General Electronics Chat' started by magicman, Feb 13, 2007.
  1. magicman
    Feb 13, 2007
    I want to drive a coil (connected to gnd [0v]) with either +3v pulses or -3v pulses. I have a micro for the control and have logic to ensure that both voltages can not be applied at the same time. The problem is the drive. What I need is an electronic 3 position toggle switch (toggle switch with center off).
    I could do it with relays but dont want the bounce abd ring plus I want quick switching times.
    I was going to use NPN / PNP darlintons (TIP22/26) or N&P channel mos FETs but cant seem to work it out. I only want to use minimal components so I did not want a H switch. I need to replicate this circuit 5 times so minimal comonets is a must. BTW, the coil is about 5 ohms.
    Your help and any suggestions are appreciated .
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    Did you try a push-pull arrangement with your BJTs or FETs?
