Reversing motor circuit
Discussion in 'General Electronics Chat' started by Joe Kells, Dec 1, 2007.
  1. Joe Kells
    Dec 1, 2007
    I have a dual voltage 110/220 motor that is a 6 wire connection. It is on a Lathe and I want to wire it for high voltage. It must be able to reverse. Is this possible considering this: The leads have to be connected this way-L1 to #1 - #3,#8,and #2 tied together and L2 to #4 and #5. To reverse, #5 and #8 have to be switched. I currently have it working on low voltage with two contactors doing the reversing but I'm not sure if I can wire it to reverse with this existing control circuit. Any advice?
  2. recca02
    Apr 2, 2007
    1,211
    i didnt get the wiring/connection,
    perhaps a forum search would help,
    for an AC motor to reverse the direction any two phases can be interchanged.
  3. Joe Kells
    Dec 1, 2007
    Reversing the direction by interchanging two phases only works on 3 phase motors. This is a single phase motor.
  4. recca02
    Apr 2, 2007
    1,211
    oops i thought it was a 3 phase motor,
    see if this helps.
