How about something like this?
With a plc, you can change design anytime without rewiring.I did not get a chance to check out the used motor donor today.
inwo, thank you for your valuable assistance. In the diagram you supplied is this a 555 timer? Yes what are the names and values of the component in your diagram? They change with the design.
when the system is running, what happens if the start is activated? will it stall and reset? No, there is no stop condition, except at limits. this would be a good addition.
I am wanting to build circuit boards for 10 targets.
Looking at a Smart Relay PLC to control random start times for each target. (This would be quite expensive for each target) so the circuit board is the less expensive option. I don't believe it will be for 10 units. Even if design was complete, the time to build and debug would exceed the cost of plcs.
The reason I wanted to have LEDs on the circuit boards is for operation and diagnostics.
Red LED = board has power
Green LED = power thru action circuit
Amber LED = power to control circuit 2nd LED for complete action circuit
Blue LED = flashes for time delay (1 flash for 3s, 2 for 5s, 3 for 8s, 4 for 10s, 5 for 13s)
press button once → target pops up and stops → setting time on delay for reverse motion target down → target movement down and stops resets process for next press of start.
anything missing let me know...
Stay with me. I'm a little slow. Language is so important when designing a circuit function. And that's one of my short comings!Build Objective 1: (ten)
1. Have a wireless command to start (future option)
2. Button is pushed and released, operates motor CW to move target (UP or forward) Got it
3. Target moves to desired point and stops motor (circuit resets till button is pushed again) Button press starts motion immediately or after the (step 4) delay?
4. Stopped target sets a time on delay to start motor again CCW (Down or reverse). Start after button press and delay time?
(Programmable delay start time for 0, 3, 5, 8, 10, 13 seconds)
5. Target moves to desired point and stops motor. (Circuit resets till button is pushed again) Home position? There are only two positions. Home and desired point. Each will have a limit switch.
I addressesd your response in REDStay with me. I'm a little slow. Language is so important when designing a circuit function. And that's one of my short comings!
I'll just try to get a firm grip on the first objective.
10 boards are needed as they are apart far enough that on large controller is not the best choice?
1 Press button to start. Once
2 Moves F until stop at limit switch.
3 No further motion until button press. Stop limit switch sets time delay to R
4 Press button to continue.
5 No motion until preset time elapses.
6 After delay, move in reverse to home limit and stop. Reset, no motion until button is pressed again
7 goto 1 Yes, only need to press start button once
Will an emergency stop switch suffice for safety? Killing power to motor circuit. So as no stop function is needed on circuit board? Yes a good safety feature to point out.
Will a standard dial-set timer work to set times? Yes I thought origionally if using the complete garage door system
Or dip switches on a circuit board? Easier than a selector switch. Programmable may require key board or display. DIP sw with LED flash for Delay, 1 flash for 3 sec, 2 flash for 5 sec, 3 flash for 8 sec, etc.
I think the only thing that I missed in my first attempts, was waiting for button press while in the "desired" position.
I understood that motion would continue automatically after set delay. ( I see it now in your original post ) YES, Button press once for complete cycle, start to home.
(I'll try to redraw diagram)
Either way, I still believe that one of these timers and one or two control relays, may be the simplest, most reliable solution.
I'm thinking that you need more travel than a typical GD screw provides.What ya thinking?
by Jake Hertz
by Robert Keim
by Aaron Carman
by Aaron Carman
