Reversing AC Motor Rotation
Discussion in 'The Projects Forum' started by jsebastian, May 23, 2014.
  1. jsebastian
    May 23, 2014
    New to the forum, eager beginning amateur.
    I am interested in creating a device that would reverse the pump motor (decorative outdoor fountain) rotation for about 5 seconds, about once per hour. The purpose would be to clear debris from the filter, which accumulates detritus and impedes water flow.
    I would appreciate any suggestions or comments. Thanks for your consideration.
    John
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    It would depend upon the type of motor. Shaded pole, out of luck. Single phase with start winding and start switch, possible, but not too easy. 3 phase, easy.
  3. #12
    Nov 30, 2010
    16,665
    7,313
    Not likely. AC motors generally can't be reversed unless they are designed that way.
    Look for an extra wire. Maybe it has a "reverse", maybe not.
    ps, also not likely that a decorative fountain has a 3 phase motor in it.
  4. inwo
    Nov 7, 2013
    2,435
    315
    Seems an auxiliary pump of some kind for back flushing is in order. Or valving.
    Even if motor is reversible, pump may not be.
  5. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,507
    Fountains of Trevi maybe!:)
    And then there are some small decorative fountains that have a DC motor.;)
    Max.
  6. #12
    Nov 30, 2010
    16,665
    7,313
    That's encouraging. DC motors can usually be reversed.
    Watch for a power converter on the pump!:)
  7. BillB3857
    Feb 28, 2009
    2,402
    348
    Depends upon the size of the fountain. I doubt if the Vegas casinos use single phase.:D
  8. #12
    Nov 30, 2010
    16,665
    7,313
    Very funny, guys. Las Vegas can afford to hire an electrician.:rolleyes:
    Metalmann likes this.
  9. jsebastian
    May 23, 2014
    Thanks, guys, I appreciate your contributions!
    John
