Hi all,
The following problem:
I have a model railroad project, where I need to reverse a DC motor (2.4V). I have the same 2.4V and no more than 20mA available as switching current. When on, the motor should be running on reverse. When off, the normal direction. Given all the space in the world, this would be dead easy. However, in this case, even a DIP 16 thing is big. Maybe I can stack two DIP or preferably SMD 8s on top of each other.
I have been looking at quad optocoupler and was quite happy to start with. But now I realise this will switch my thing in one direction on nicely, but there is no way to switch on the other direction, since there is no "off" switches when the switching current is on. Are there optocouplers that act in the opposite direction? I mean, when the led is on, the switch is off. Or maybe there are much better ideas and solutions out there...
Thank you for your time,
/Edmunds
/Edmunds
