Reversing a 12v actuator using dpdt relay and a joystick wobble switch 2no contacts
Discussion in 'The Projects Forum' started by bergybob, May 23, 2016.
  1. bergybob
    Dec 28, 2011
    27
    Hi, I have been helped on this site before with a chook house door opener.
    This time i want to use a 12v actuator via a dpdt relay to steer my boat .I have drawn a diagram and would like imput on how close i am .Will it work ?
    I have purchased a 2 position joystick wobble stick panel mounted 2 no centre off.A 12 volt actuator .and other sundry diodes and relay.
    Can you please have a look at my diagram and tell me if i am on the right track.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Are your motor and/or actuator reversed when the DC voltage to them is reversed? What type of actuator is it?
    John
  3. #12
    Nov 30, 2010
    16,665
    7,313
    You aren't speaking my language with that drawing. Is this what you're trying to do?
  4. AlbertHall
    Jun 4, 2014
    2,261
    447
    Depending on exactly what the switches in the box marked 'Toggle Switch' do then it might,
    if both diodes are reversed and if the 'Toggle Switch' can handle the full actuator current.
  5. bergybob
    Dec 28, 2011
    27
    Hi John,The actuator is from ebay 12 volt with inbuilt limits.
    Yes the actuator is reversed when the current is reversed.
  6. bergybob
    Dec 28, 2011
    27
    Hi,Yes,from my limited knowledge of circuits your diagram does do what i am trying to do.
    Hold the toggle switch forward and the actuator goes one way.Let the toggle go and it returns to centre and all movement ceases.Put the toggle back and the actuator runs in reverse.
  7. #12
    Nov 30, 2010
    16,665
    7,313
    The circuit I drew does not provide a powered return to center. That would require a feedback function according to position.
    If external forces return the actuator to center, that is OK, but the switches won't do it because they don't know where center is.
  8. bergybob
    Dec 28, 2011
    27
    The toggle is spring loaded and returns to centre when pressure is removed,automatically.
  9. #12
    Nov 30, 2010
    16,665
    7,313
    Yeah. I know how a joystick works. That's why I said, "actuator". The actuator won't return to center unless you power it or some external force returns it to center when you are not applying power.
  10. bergybob
    Dec 28, 2011
    27
    Ok sorry i read it wrong, the power for the return i would think would be to push the toggle to the other side and energise the reverse power to the actuator.
