Reversible Synchronous Motors
Discussion in 'General Electronics Chat' started by jerseyguy1996, Dec 23, 2013.
  1. jerseyguy1996
    Thread Starter Active Member
    Feb 2, 2008
    206
    9
  2. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,502
    I would guess that is a AC stepper motor, as opposed to the identical DC bi-polar pulsed stepper.
    The AC version uses a capacitor to provide a 90° phase shift of the applied frequency for a very accurate synchronous amount of steps/rev. 72rpm on 60Hz.
    Practically instantaneous stop/start and can be stalled without damage to the windings.
    The capacitor is swapped between windings just as a 1ph split phase induction motor is reversed.
    Max.
  3. jerseyguy1996
    Feb 2, 2008
    206
    9
    I think I understand. I have a hard time wrapping my head around the whole capacitor causing a phase shift concept but this gives me a good starting point. Thanks!
  4. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,502
    If you think of two windings fed from the AC but one is in series with a capacitor, in the direct connected winding the current will be in phase with the applied voltage, in the series connected winding, the current will be supplied through the capacitor, in a capacitor, the current leads the voltage, causing a phase difference between the two windings, swap the windings and the direction will change.
    Max.
    jerseyguy1996 likes this.
  5. jerseyguy1996
    Feb 2, 2008
    206
    9
    That clears it up completely and also tells me why the motor behaved very oddly(but certainly did not turn off like it was supposed to) when I tried controlling it with a relay in between the capacitor and one of the windings. The other winding was still getting power. I need to place the relay at the node before the capacitor. Basically I just need to place the relay on the line from the mains, which is what I should have done from the beginning but I was trying to be fancy about it.
  6. MaxHeadRoom
    Jul 18, 2013
    10,835
    2,502
    If in doubt, follow the instructions! :)
    Max.
