The attached motor is for an electric pool cover. I would like to build or buy a control board for this motor. Any suggestions?
Well that is indeed a puzzle. Normally neutral and the 120 volt return are the same line. But if you connect them that way, there would be no voltage across the main motor winding. Either there's an error in the drawing or neutral and return are not the same connection.Thanks. I am still a bit confused how the motor works.
Where would I wire the Yellow and blue wires?
What do I do about the starter circuit?
