Hiya. I am having a dilemma and not being an electronics guy, its making my head hurt and it's probably an easy layout.
I'm using a 115VAC, 1/2 HP Split Phase motor from Grainger (6Z403) which will be coupled with an acme screw. I need this to move a tower from the 0 degree position to a 90 degree position. I have attached a pdf of the tower in the 90 degree position. I'd like to accomplish this by using limit switches as I don't want the unit to keep turning and tear itself apart.
As I've stated, I'm not an electronics guy but a mechanical one so I'm pretty much at a loss as to how to wire this with the correct switches. It will be wired into a keyed switch on the wall as this is an overhead unit.
Thanks for your help! Chris
