reverseing a motor?
Discussion in 'General Electronics Chat' started by Verdict_Guilty, Mar 30, 2014.
  1. Verdict_Guilty
    Mar 30, 2014
    hey I use these forums but never had an account but now I have become curious about something and cant get much information on it so any little thing will help :)
    I bought an old lathe last week and set it up its going like a charm :D the old guy who owned it has it run off an old washing machine motor which he has done some nice work to make it go forward and reverse and also has put a variable speed on it which is really handy but i was wondering if someone could explain to me how this is done? Im not very good with electronics i have the bare basics we learn in college (im studying mechanical engineering so we don't do much electronics). If anyone could help me id really appreciate it
    Jimmy
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    You need to find out the technology of the motor, a simple (older) 1ph split phase washing machine motor does not vary speed, not without problems anyway, if this was a variable speed on the washer, then it is either a Universal motor, controlled by a Motorola TDA1085 IC controller or a later brushless multi-pole AC motor.
    Max.
  3. Verdict_Guilty
    Mar 30, 2014
    Thanks for the reply :) by the look of it I think the old fellow put it all together himself there's two simple boards on it. How would I find out about the motor? or is there a way to do it?
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Take any info off the motor plate, or post a photo, if possible and the boards.
    Max.
  5. Verdict_Guilty
    Mar 30, 2014
    Okay cool I had it down earlier today looking at it so il get some pictures tomorow :)
  6. debe
    Sep 21, 2010
    955
    185
    This is how I wired an old washing machine induction motor for a lathe, so it could be reversed.
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Reverse is usually no problem, it is varying the speed that would be the challenge. ;)
    Max.
  8. Electric Al
    Member
    Nov 6, 2013
    59
    8
    Use an On / OFF / On switch. images.jpg
    Picture is double pole , but single pole are available !
