Reverse voltage protection using a diode?
Discussion in 'General Electronics Chat' started by AgeingHippy, Jun 30, 2011.
  1. AgeingHippy
    Nov 28, 2010
    16
    Hello All
    I am building a simple motor controller and was thinking about reverse voltage protection.
    Is it possible to provide reverse voltage protection to my board by simply placing a diode on the Vcc and Vcc2 input lines? (with Vcc being my 5+ logic voltage and Vcc2 running between 3-32volts). The motor driver should run a maximum of 2A on Vcc2 and minimal on Vcc.
    If so, which diodes would I use? I have the following in stock:-
    1N4001 Rectifier diode 1A 50v
    1N4002 Rectifier diode 1A 100v
    1N4148 Signal diode
    1N914 Signal diode 75v
    SB160 Schottky 60v 1A
    N5821 Schottky 30v 3A (seem very chunky so probably overkill)
    It would be usefull if you could tell me what I should take into account when selecting the diode. What to look for on the relevant datasheets etc. I imagine a fast switching diode is unneccesary so a Schottky diode would be unneccesary.
  2. Bernard
    Aug 7, 2008
    4,230
    412
    For VCC, I would use a 1N4002, cathode to load side of 1/2A to 1 A fuse, anode to ground. 5V ckts. using 5V do not like 4.3V so a series diode not advisable. For VCC2 A 3A diode in series should be OK, one 3A or 3 parallel 1N4002's.
  3. AgeingHippy
    Nov 28, 2010
    16
    Hi Bernard
    So do I understand that for Vcc (the 5volt side) you are suggesting using a diode to cause a short circuit between VCC & GND if reverse voltage is applied?
    Cheers
  4. tom66
    May 9, 2009
    2,613
    214
    Never put diodes in parallel unless they are thermally coupled. The nonlinear behaviour of them will lead to one taking all the current which would cause it to overheat.
  5. mcgyvr
    Oct 15, 2009
    4,783
    973
    Diodes are great for reverse voltage protection.. But as stated above, diodes have an associated voltage drop. If you can live with that then go ahead.. If you can't sometimes you need to look for other methods.. Even something as simple as a "keyed" connector can be used that prevents it being installed in backwards. Of course there are many times when that doesn't work either.
  6. Bernard
    Aug 7, 2008
    4,230
    412
    When fuse blows there is no more VCC on ckt., diode is still in ckt. Diode only has to be rated for fuse capacity & can carry considerlby more than rated current on a one shot basis .
  7. Jaguarjoe
    Apr 7, 2010
    770
    90
    At first, I misunderstood where the diode was, About 47μS after I hit the submit button, it became very clear very quickly that I was on the wrong road.
  8. radiohead
    May 28, 2009
    474
    31
    I would suggest using a bridge rectifier module for reverse polarity protection. I use them.
  9. Bernard
    Aug 7, 2008
    4,230
    412
    On a 5V ckt.?
  10. JMac3108
    Aug 16, 2010
    349
    66
    You may be confused about how to use a diode for reverse polarity protection. There are two ways to do this ... seried diode, or parallel diode.
    (1) Series diode: Just place the diode in series with the input voltage. When the input is the correct polarity, current will flow. When votlage is reverset, current will be blocked. Make sure the diode can handle the maximum input current and check that it won't get too hot. Remember, there will be a voltage drop across the diode, this reduces the input voltage to your circuit.
    (2) Parallel diode. Place a reverse biased diode from your input to ground AND place an externally accessible fuse in series with the input, before the diode.Tthe diode has no effect when the input voltage polarity is correct. But, the diode acts like a short when reverse voltage is applied and blows the fuse. If possible, choose a diode that can handle the fuse current, but remember that the diode will only conduct current for a short period of time and therefore will not heat up and fail, even if it is under-rated (be sure to test this). Use this scheme when your circuit can't tolerate the voltage drop from a series diode.
    elec_mech likes this.
  11. tom66
    May 9, 2009
    2,613
    214
