Reverse Pulse Relay
Discussion in 'The Projects Forum' started by James Steele, Jun 18, 2008.
  1. James Steele
    Jun 18, 2008
    I am in need of a low voltage coil SPST relay (5-12vdc) that when voltage is applied, the relay contacts momentarily close and when voltage is released from the coil, the contacts momentarily close again. Is there anything like that in the marketplace or can be constructed? Thansk in advance for any input.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    See the attached for a couple of ideas.
