Reverse polarity switch in combo with Cyclic timer.
Discussion in 'The Projects Forum' started by Sarah Dale, Apr 8, 2015.
  1. Sarah Dale
    Apr 8, 2015
    Hi, I have wired up a DPDT switch so that it reverses the polarity. Im using it with a mechanical device I built that will switch the switch after a certain period. This all works well. However I do not want the machine to run constantly so I have bought a cyclic timer <https://www.quasarelectronics.co.uk/Item/cebek-i-11-12vdc-cyclic-timer-relay-module-1-30-minute> that will switch the whole think off after a period. I don't have a clue how to wire up these two items, and would appreciate any suggestions. The switch is wired thus. <http://www.gamainc.com/site/largepics/941/130299/487365/676821/Polarity_Reversing_Toggle_Wiring.jpg>
  2. djsfantasi
    Apr 11, 2010
    2,905
    878
    The ">" character has become appended to your URL. It has to be deleted for the link to work.
    You don't want the device to run constantly, but how long do you want it to work? How long does it run before reversing?
    The device manual (<-click link) shows how to wire a load (your device) to it, so that it operates with the cycle you set on the board. The switching is done with a relay, so in addition to switching the power, it can be used to switch a signal to a controlled device.
  3. djsfantasi
    Apr 11, 2010
    2,905
    878
    Is this what you are thinking?
  4. Sarah Dale
    Apr 8, 2015
  5. Sarah Dale
    Apr 8, 2015
    Okay thanks. Ill give that a try :)
