Reverse polarity solenoid
grf500
Joined Aug 19, 2013
8
Hi all, new on here and hoping that someone will help me.
I want to run a motor in one direction, only for a second, using a momentary switch, then again in the opposite direction using the same switch. It is a small 12v motor very low current.
I am sure similar has been asked before and I have seen something using a couple of 555 timers, or a single 556 and two relays but cannot find it again.
grf500
Joined Aug 19, 2013
8
Thanks for the pointer. I should say that I have zero experience and know nothing about electronics in comparison to you guys, but I have a desire to learn.
I guess what I am after is using the timers as monostables, but its the single momentary switch to control it all that causes the difficulty.
shortbus
Joined Sep 30, 2009
10,045
So if I understand your first post -
1. turn on switch
2. motor runs in direction "A" for 1 second
3. motor then runs in opposite direction, until switch is shut off
Is the above sequence what you want to do? How close does the '1 second' have to be?
grf500
Joined Aug 19, 2013
8
1. turn on switch
Hi Shortbus
Very close, what I want to achieve is
1. Momentary press switch
2. Motor runs forward for 1 second
3. Momentary press same switch
4. Motor runs in reverse for 1 second
The 1 second is not critical, its to push/pull a lock motor and can be controlled with limit switches at both ends of travel.
Thanks for your help
praondevou
Joined Jul 9, 2011
2,942
I think you should decide first if it can be controlled or if it will be controlled via limit switches.
If limit switches are present you actually don't need a monostable.
grf500
Joined Aug 19, 2013
8
Thanks Praondevou, my thouht was that it can be controlled by the limit switches if needed. The single momentary switch would be the controlling element.
grf500
Joined Aug 19, 2013
8
Thanks for your efforts Shortbus, that looks good but, will that not keep reversing direction every time one of the switches is pressed? what I am after is
1 brief press of s1
2 motor runs forward max 1 second, can be cut with limit switch
3 motor stopped
4 brief press of s1
5 motor runs backwards max 1 second can be cut with limit switch
6 motor stopped
Sorry if I wasnt clear in earlier post, I have found lots of circuits using more switches but I can only have 1.
MaxHeadRoom
Joined Jul 18, 2013
28,688
I have a flip/flop circuit using one PB and two relays for picking up the motor and reversing it.
Plus a couple of diodes and caps.
I have used it in the past in place of a S.S. circuit where a relay is needed anyway.
You would need the limit switches though.
I can dredge it up if interested?
Max.
praondevou
Joined Jul 9, 2011
2,942
This does what you want. The relay needs to be one with low coil current. A small signal relay will do it. The flipflop just toogles between one state and the other every time you press the momentary button. The relay then switches and reverses the motor direction. The motor movement is stopped solely by the limit switches which are normally closed,i.e. they are closed whenever the motor is not in its end position.
If you can live with a toggle switch instead of a momentary button you could remove the relay and flipflop. If this is battery powered you will want something without a relay, it will consume to much current.
grf500
Joined Aug 19, 2013
8
Thanks Praondevou, looks ok other than current consumption because as you mention it is battery powered. It does need to be a momentary push switch as well :(
praondevou
Joined Jul 9, 2011
2,942
Ok then use a single coil latching relay like this one: http://www.digikey.ca/product-detail/en/V23079B1203B301/PB1085-ND/1633971
The output of the FF that goes low will trigger the connected 555. The timer makes sure the relay is only powered as long as is needed to switch it in the other direction. It stays there until the other 555 is triggered , when you press the button again. The schematic is not complete as see, the components around the 555s and some connections on the FF are missing.
MaxHeadRoom
Joined Jul 18, 2013
28,688
Here is the relay version I have used the circuit with a couple of OMRON MY4 relays, any other type may need an adjustment of the R & C, the original circuit had 6 pole relays which in that case you can eliminate the 3rd relay C.
Max.
grf500
Joined Aug 19, 2013
8
Cheers Max, I may have to knock up a trial version of that and have a play.
Really appreciate the advise from all, I am indebted to you.
Dave
MaxHeadRoom
Joined Jul 18, 2013
28,688
The original circuit had 6 pole relays with 175ohm coil and 75μf cap and 23ohm resistor.
This was purported to be tested over 2000 operations at 12/sec!
I couldn't imagine pushing the button that fast!
Circa 1962.
Max.
MaxHeadRoom
Joined Jul 18, 2013
28,688
Dave
BTW, you have to be careful with the terminology, I got into deep water when I first used that expression when I first came to Canada, It has an whole different connotation here.;)
My neighbor did not want to be late for work so I told her I would knock her up in the morning!
Max.
