Reverse polarity protection
qitara
Joined Jan 18, 2013
112
Hi
What is the best method to protect a device like an inverter from reverse polarity connection ?.
I am thinking of an diode in series.
#12
Joined Nov 30, 2010
18,224
It depends on how many killowatts the inverter inverts. Sometimes it is just too wasteful to use a diode. A better method might be to use a polarized connector so nobody can plug it in backwards.
qitara
Joined Jan 18, 2013
112
the inverter was just and example, what i meant was in general.
Is the diode method not good because it will act like a resistor and lower the voltage ?
#12
Joined Nov 30, 2010
18,224
Sometimes, yes. Sometimes, no. If you're trying to feed a 5 volt regulator for a digital chip with a 9 volt battery, the diode will not make any difference. If you are trying to feed 30 amps DC into the load, the diode will be large and wasteful.
#12
Joined Nov 30, 2010
18,224
Even simpler, a fuse first and a diode that is arranged to short circuit any backward polarity that suddenly arrives at the input terminals. This method eliminates the need to calibrate a crowbar circuit to the expected input voltage.
inwo
Joined Nov 7, 2013
2,419
That's the way most commercial products do it.
And the best way IMO
Consumers will figure out how to defeat it though.:D
So use a big enough diode to blow the input pcb trace.
They will keep putting in bigger fuses until they run out, and then use tin foil.:eek:
30,795
You can put a bridge rectifier on the DC power input of a device so that it doesn't matter which way the power source is connected.
You will lose about 1.3V from two diode voltage drop.
#12
Joined Nov 30, 2010
18,224
Full Wave Bridge advantage: Either way you connect the supply, only the right polarity will get to the load and the load will work.
Disadvantage: TWO diodes dissipating energy during all times of proper operation.
Single diode in series: proper connection works, improper connection simply does not supply any current, one diode always dissipates energy during proper operation.
Fuse with shorting diode: proper connection works, improper connection does not supply any current after some small time period, zero diodes dissipating energy during proper operation, improper connection results in a need to replace the fuse.
There are other ways, like a relay, a PTC thermistor, and mosfet switches. Would you like to discuss those methods?
kubeek
Joined Sep 20, 2005
5,795
Another common approach for higher wattages is a mosfet instead of the diode, this doesn´t waste much power and is usually not too big either.
34,412
To use a MOSFET, it must be a type to fully turn on with the nominal supply voltage. Thus for anything less than a 10V supply, it must be a logic-level type MOSFET.
Also a Schottky diode will reduce the forward voltage drop as compared to a standard junction diode.
