Hi Guys
Im using an analog devices DG412 analog switch to turn on a 24VDC relay. The 5v logic signal from the micro will cause the DG412 to switch the 0V side of the relay thus energising the coil.
This works perfectly, but i want to add some protection. Because there is a connector to the outside world where an electrician will wire the relay, i want to protect against reverse connection. ie at the moment if +24V is applied to D1 of the DG412, it will blow, the current output is only 30mA max of the DG412.
How can i protect against this condition? I cant use blocking diodes because then my sinking signal wont switch the relay.. I could use a current limiting circuit? but i dont want to get too complex.
any thoughts much appreciated, hope the diagram makes sense. it is not quite complete, but IN1, IN2 etc is the logic signal from microcontroller. D1, D2 etc are connected to (-ve) side of relay coil, and S1,S2 etc are connected to the 24/0V level. VCC is +5V in this case, the supply for the microcontroller logic levels.
