reverse polarity protection for voltmeters
Discussion in 'The Projects Forum' started by eceeng, Sep 12, 2007.
  1. eceeng
    May 8, 2007
    10
    what is the best way to protect a voltmeter or VOM from the damages brought by connecting the device in the wrong polarity?
  2. Neo1130
    Member
    Sep 3, 2007
    13
    MOST of them should have it built in if I am not mistaken...
  3. recca02
    Apr 2, 2007
    1,211
    diodes i guess.
  4. techroomt
    May 19, 2004
    198
    if you are talking digital display, then the meter will just read the value in negative notation.
    the analog display type, or vom, will attempt to deflect the needle below zero and can damage the movement. they are not protected that i am aware of. the exact reason why techs should be aware of the "expected voltage polarity" reading before inserting leads - always a good idea. so the best protection here is knowledge.
    however, in the event a negative going needle is observed, a quick removal of the probes will lessen the likelyhood of movement damage.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A modern instrument has built-in overvoltage protection and is insensentive to applied polarity. It just gives the reading and wheather it was positive or negative with respect to the common kead.
    When you say VOM, I think of Simpson 260. It had P-poor overvoltage and you just watched the needle bounce off the left stop when testing the wrong polarity.
  6. Neo1130
    Member
    Sep 3, 2007
    13
    Didn't they also have circuit breakers in them that would pop in this certain condition?
  7. Distort10n
    Dec 25, 2006
    429
    My Fluke has fuses; although I forget the amperage rating.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The fuses are in the current measuring circuit. 350 ma and 10 amps for my Fluke 23 (both are original).
