Reverse Polarity Protection for Dual Polarity supply power
Discussion in 'The Projects Forum' started by enggricha, Jun 3, 2016.
  1. enggricha
    May 17, 2014
    62
    I have a -15V - 0V(Gnd) - +15V power source that I have to connect to a PCB while ensuring that if any two of these, or all three are connected wrong still there is no damage to the PCB. Is there practically viable way to do this. I know implementing a reverse polarity protection of a +15V - 0V (Gnd) is straight forward and I have done that many times, with diodes and P-channel FETs.
    Have spend a couple of days on this and haven't been able to come up with any way to do this.
    TIA,
    Richa.
  2. Dodgydave
    Jun 22, 2012
    5,166
    775
    Yes, you can use inputting diodes in series with each pos and neg legs this will however drop a small voltage, OR use diodes in reverse across the supply, the latter will blow the fuses on the psu and wont drop any forward voltage.
    #12 likes this.
  3. AlbertHall
    Jun 4, 2014
    2,281
    450
    That protects against reverse voltages but if the -15V and 0V are swapped then 30V will be applied between +15V and 0V, so some overvoltage protection would be required as well - VDR, crowbar...
  4. enggricha
    May 17, 2014
    62
    I agree with albert here. Infact this is the problem area that I got stuck at. RVP_1.gif
    I saw this schematic elsewhere. As albert mentioned if we swap GND and -15V we will have a 30V across the intended +15V and GND.
    What am not understanding here?
  5. AlbertHall
    Jun 4, 2014
    2,281
    450
    If your power supply has a reliable current limit then two shunt schottky diodes should do the job. In the case where the -15V and 0V connections are swapped then the -15V supply will be shorted to 0V by the diode thus restricting the +15V (which would otherwise have been +30V) to 15V + one diode drop. The series diodes shown in your diagram would stop that happening though.
  6. crutschow
    Mar 14, 2008
    13,509
    3,385
    You can use an N-MOSFET (no diodes) to provide minus voltage reverse protection, the same as you use a P-MOSFET for positive voltage reverse protection, as shown below.
    Here's an explanation.
  7. AlbertHall
    Jun 4, 2014
    2,281
    450
    If the power is mis-connected then does this not also result in 30V across the R+Load?
  8. crutschow
    Mar 14, 2008
    13,509
    3,385
    Yes, but that's an unusual mis-connection.
    Normally it's just interchanging the plus and minus connection that is the problem since the power supply grounds are usually connected together internally in the supply.
    The only way to prevent the problem you show is to add an OVP circuit.
  9. AlbertHall
    Jun 4, 2014
    2,281
    450
    The shunt diodes do work for all mis-connections .
  10. #12
    Nov 30, 2010
    16,705
    7,358
    You might use a 3 pin connector that can only be plugged in one way.
  11. crutschow
    Mar 14, 2008
    13,509
    3,385
    Until the diode opens from the short circuit current.
    You likely need to add a fuse to the shunt scheme (and I hate fuses).
  12. AlbertHall
    Jun 4, 2014
    2,281
    450
    Most regulated supplies include a current limit - sorted.
  13. tom_s
    Member
    Jun 27, 2014
    287
    342
    aka polarised/polarized connectors (depending on which side of the planet you on)
  14. crutschow
    Mar 14, 2008
    13,509
    3,385
    The OP said "power source" not power supply so don't know if it's current limited.
